New convert under way  - Page 27 EmptyToday at 9:51 am by kevin924kevin
New convert under way  - Page 27 EmptySat Nov 16, 2019 9:00 am by j7wolfe
New convert under way  - Page 27 EmptyFri Nov 15, 2019 6:34 pm by Hey_Allen
» LS engine & Trans "upfront", Mustang IRS in the "rear"
New convert under way  - Page 27 EmptyMon Nov 11, 2019 5:59 pm by sparkydog
» WTB: Trailing Arm Bushings
New convert under way  - Page 27 EmptyMon Nov 11, 2019 9:18 am by Hotrodz of Dallas
» 82 924 with AUX Audi V8.
New convert under way  - Page 27 EmptySun Nov 10, 2019 2:35 pm by Golten1986
New convert under way  - Page 27 EmptySun Nov 10, 2019 5:13 am by superman22x
» Introduction/CA-SMOG '86 turbo
New convert under way  - Page 27 EmptySat Nov 09, 2019 8:29 pm by pormgb
» 944-LT1 LS3 Conversion
New convert under way  - Page 27 EmptySat Nov 09, 2019 7:49 pm by Ordie792002
» Lexus BBK Big Brake Kit
New convert under way  - Page 27 EmptySat Nov 09, 2019 6:19 pm by Red944ls1
November 2019
Page 27 of 30 Previous  1 ... 15 ... 26, 27, 28, 29, 30  Next
New convert under way  - Page 27 Empty Re: New convert under way
Post  944convert on Sun Mar 25, 2018 9:01 am
some more info from another forum...
"you can't stick a late tank in an early car unless you change the strap location pick up points, cut the crossmember out, then make it a bolt in, tap the longitudinals, match the resistance signal from the new sender to the old gauge......"
Post  kevin924kevin on Sun Mar 25, 2018 10:31 am
For me to use a newer tank I would remove a section of the floor and replace that section with the floor from a newer car. This gives me the locators and factory mounting points. The relocation of the strap is minor. As for fuel gauge I am running all Auto meter gauges. Simply change the unit to a auto meter unit. Adjust mounting  holes and good to go. The cross member removal is 5 min.  I have a piece of 1.75 dom tubing running between my shock mounts and frame. So still have good rugity in the ass end. Plus my tran's hangs off of it.. I appreciate the info.
Post  kevin924kevin on Fri Jul 27, 2018 12:22 pm
Well after a long break from my hot rod, i am back at it. My wife has finally been given the all clear from her cancer. Now its time to finish this project. I look forward to installing all the parts i have acquired over the last year. Most importantly i look forward to hearing this unit run. Forward ho. Happy days.
Post  Hotrodz of Dallas on Fri Jul 27, 2018 12:32 pm
kevin924kevin wrote:Well after a long break from my hot rod, i am back at it. My wife has finally been given the all clear from her cancer. Now its time to finish this project. I look forward to installing all the parts i have acquired over the last year. Most importantly i look forward to hearing this unit run. Forward ho. Happy days.
It's great to hear you are back working on your car. But, it's even more awesome that your wife is clear of cancer. Congrats to you both.
Hotrodz of Dallas
Hotrodz of Dallas
Post  kevin924kevin on Fri Jul 27, 2018 12:49 pm
Thank you, it make us both very happy.
Post  kevin924kevin on Wed Oct 10, 2018 2:51 pm
Robs adapters are on page 20 of my build.
Post  Blessediam on Sun Dec 30, 2018 5:06 pm
Many blessings to you and your wife with her bout and victory, the C word hits close to home for me, just chiming in watching and enjoying this build....
Blessediam
Post  kevin924kevin on Mon Dec 31, 2018 8:27 am
Thank you for your thoughts, yes the c word is a horrible thing. Car is coming along, I will update the pics and info in the new year. Happy New Year.
Post  JSP on Wed Aug 28, 2019 2:55 pm
Does anyone know what happened to this build?
JSP
Post  kevin924kevin on Wed Aug 28, 2019 3:06 pm
This build is still going. Will update pics etc in a few weeks.
Post  JSP on Wed Aug 28, 2019 3:12 pm
Great ...I'm most likely going to do the same to mine as I've already done the LS3 swap over a year ago
and love it.. 530 hp to the wheels is a blast but original 951 trans won't last forever. Thanks for taking the time to do this write up, great pictures..
JSP
Post  kevin924kevin on Mon Sep 02, 2019 10:35 pm
Rad cradle tacked up.
Post  kevin924kevin on Tue Sep 24, 2019 5:01 pm
Question, i am finally happy with my motor and trans location. How close is to close on the oil pan to rack. Mine is a manual rack. I have at best a 1/8". i am going to shave down the top of rack a bit. i really dont want to raise my motor any more as it does create an issue with my brake MC which i will have to move up and change pedal mount accordingly. I have tacked my new trans support and plates in place. I need to finalize this so i can set the supports to the trans for welding.
Post  sharkey on Tue Sep 24, 2019 6:30 pm
if your solid mounted it should be fine. if your on urethane its cutting it close, and with rubber mounts is will sag and hit it.
when i did my swap i had just over 1/8" at the tightest spot with urethane bushings and it never hit. i eventually changed my bushings out for stiff rubber ones and it only took about a month before the oil pan was on the rack. i ended up making a 1/4" thick shim to put between the frame and mount and ive never had it hit since.
Post  kevin924kevin on Thu Sep 26, 2019 8:10 am
Thank you for the reply. I removed the rack and clearenced the top section. I have a solid quarter inch now. I have tacked in primary trans support next is the secondary support at the back to stop the trans from twisting.
Post  kelleysj on Sat Sep 28, 2019 3:38 pm
I can't wait to see this build....I check for updates every time I log on.
kelleysj
kelleysj
Post  kevin924kevin on Fri Oct 11, 2019 5:22 pm
Suspension under the car baby steps.
Post  kevin924kevin on Fri Oct 11, 2019 5:27 pm
Should work.
Post  kevin924kevin on Tue Oct 15, 2019 2:57 pm
so i ordered up the rubber today. I bought the Toyo Proxes T1R Rf 315/25ZR19 rears and 255/35ZR19 fronts. Nice aggressive tread pattern Good reviews.
Post  kevin924kevin on Tue Oct 15, 2019 3:01 pm
Post  kevin924kevin on Tue Oct 22, 2019 4:19 pm
So rad mount is ready for finish and my alum rad is ready for pickup. had mounting tabs etc welded on. My main rear cross member plates are ready as well. With the plates this will finally allow complete button up of the chassis and the transmission, then finally i can set the car down for the first time in 8 or 9 years.
With the rad complete this now moved me closer to that first start up. slow and steady.
Post  kevin924kevin on Sun Oct 27, 2019 11:55 am
Rack rebuilt and installed.
Post  kevin924kevin on Sun Oct 27, 2019 12:08 pm
Finely hydro boost fitting and location resolved. I will have to relocate my clevis up about 1/2or so up to allow push rod to be parallel to the unit. Question BMW unit. What's the best location for the reservoir?.
Post  kevin924kevin on Sun Oct 27, 2019 12:12 pm
I have fabbed up the mounting bracket and desided  on this location for the bomb.
Post  kevin924kevin on Sun Oct 27, 2019 12:13 pm
