» Dual MC Mounting Bracket
Today at 8:11 pm by 87944turbo
Today at 7:50 pm by hp18racer
Today at 5:20 pm by dougr944
» Need help! Car won’t start
Today at 3:51 pm by jess2suityou
Today at 9:44 am by keetle
» Brand new ls3 build
Today at 9:32 am by Plucky948
» Lighten clutch pedal feel?
Today at 1:35 am by Porsche951toLS3
Yesterday at 9:54 am by docwyte
January 2019
78910111213
14151617181920
21222324252627
28293031
New convert under way
Page 26 of 27 Previous  1 ... 14 ... 25, 26, 27  Next
Re: New convert under way
Post  kevin924kevin on Sun Feb 25, 2018 9:05 pm
Thank you superman22x. What I have done so far was actually banged the tank all over with my hand and I was surprised by how much rust came out. I then used compressed air and that did a pretty good job of cleaning the tank for now. After a close inspection I think the tank can be dipped hot tanked and coated and be good to go. I have a local shop that does this. So I am going to take it down and see what they say.
Post  kevin924kevin on Sun Feb 25, 2018 9:12 pm
So today's progress. Released the engine pulled the passenger side motor mount. Reshaped the metal shim between the mount and my cross member. This allowed the motor to roll more to the PS and level it out. I moved the trans/torque tube over to set the alinement. I needed to do this to bring the oil pan up on the drivers side to give me more space between my rack and pan. I have about a 1/4 inch now. I think this should be enough.
Post  kevin924kevin on Tue Feb 27, 2018 8:15 am
Well i discovered a small glitch. My torque tube hits the front of the tunnel on the top. My motor is sitting were it needs to be. My trans height is where i want it to be , it is sitting just a hair above the bottom of the floor. So now i will trim the front of the tunnel to give it the room it needs. For me this is all part and parcel with not doing the cross member drop. I also removed the brace between the frame rails at the front of the car, This is going to allow me to move the rad forward and to angle the unit so when i cut openings through the top of my hood there will be a nice flow of the hot air out of the engine bay. The build continues. I will post a few pics later of what i am talking about.
Post  kevin924kevin on Tue Feb 27, 2018 12:27 pm
Post  kevin924kevin on Tue Feb 27, 2018 12:32 pm
The problem is right were the weld is. The tunnel slopes down on both sides.  I will redue the top of the entire tunnel to make sure I have good clearances.
Post  kevin924kevin on Tue Feb 27, 2018 12:34 pm
Post  kevin924kevin on Tue Feb 27, 2018 12:35 pm
Post  kevin924kevin on Tue Feb 27, 2018 12:45 pm
The shim I talked about.
Post  Hotrodz of Dallas on Tue Feb 27, 2018 3:42 pm
Looking good as always
Hotrodz of Dallas
Post  kevin924kevin on Tue Feb 27, 2018 3:48 pm
Thank you, tonight i start the rad mount.
Post  kevin924kevin on Wed Feb 28, 2018 9:56 am
Well got the news on my gas tank. It was acid cleaned and pressurised. That part was good no leaks, The problem is there is some sort of a chamber in my tank which is preventing them from doing the liner. It ties in with the small vent pipe on the top. which they cannot access. So at this point i have to decide what i am going to do for a fuel tank. It either a cell and mods or buy the newer poly tank and make that work. I was hoping for simplistic that the old tank could be used, so back to the drawing board on that. I may look at my tank closer and see maybe i open the top of the tank and do a new sealed plate. I just dont want any crud going through all my new parts, pump filter injecters etc.
Post  chrenan on Wed Feb 28, 2018 10:49 am
My vote would be for fabricating some straps similar to those that hold the stock tank, but for a fuel cell.
chrenan
Post  Hotrodz of Dallas on Wed Feb 28, 2018 1:22 pm
kevin924kevin wrote:Well got the news on my gas tank. It was acid cleaned and pressurised. That part was good no leaks, The problem is there is some sort of a chamber in my tank which is preventing them from doing the liner. It ties in with the small vent pipe on the top. which they cannot access. So at this point i have to decide what i am going to do for a fuel tank. It either a cell and mods or buy the newer poly tank and make that work. I was hoping for simplistic that the old tank could be used, so back to the drawing board on that. I may look at my tank closer and see maybe i open the top of the tank and do a new sealed plate. I just dont want any crud going through all my new parts, pump filter injecters etc.
Since you have the room to use whatever tank you want, I would say absolutely use the factory poly tank. It will hold more fuel and won't rust ever. Otherwise, find a fuel cell that will fit in your car.
Plus having sealed many motorcycle fuel tanks, I've seen many of them that the sealer will start coming apart on, and you get major plugging then.
Hotrodz of Dallas
Post  kevin924kevin on Wed Feb 28, 2018 1:38 pm
thank you all for your imput. Any body have a few good pics of how the poly tank mounts? This would be my first choice as i am trying to save the spare tire carrier.
Post  chrenan on Wed Feb 28, 2018 1:50 pm
Here's a pic from my chump car team during our build.  We pulled the poly tank to clean it, but also so we didn't melt it while welding the cage legs above it, something you'll want to remember if you have a poly tank and are installing a cage.
You can see the two large protrustions, they hold a captive nut. A large bolt and washer pass through two openings in the tank to hold it to the trunk floor. There's also a strap which secures the fuel pump cover plate and supports the pump.
chrenan
Post  Hotrodz of Dallas on Wed Feb 28, 2018 2:07 pm
There is one strap and the fuel pump housing that goes under the sump part of the tanks. There are two holes through the tank that bolt it to the body. Hopefully the pics show what i'm talking about.
Hotrodz of Dallas
Post  kevin924kevin on Wed Feb 28, 2018 2:17 pm
Thank you both for the info. So no cross member holding the front of the tank like i had. Those dimples can be duplicated for my application, So just bolted up through the rear compartment floor and a strap. This is a good option for me. Again thank you.
Post  kevin924kevin on Thu Mar 01, 2018 6:34 pm
OK one more question, how thick or tall is the poly tank at the front edge. Why, I need to make sure I have enough room to clear the Z06 trans. My steel tank narrow's at the front to go over the cross support that holds the front up. I appreciate the info.
Post  Hotrodz of Dallas on Fri Mar 02, 2018 2:15 pm
kevin924kevin wrote:OK one more question, how thick or tall is the poly tank at the front edge. Why, I need to make sure I have enough room to clear the Z06 trans. My steel tank narrow's at the front to go over the cross support that holds the front up. I appreciate the info.
The front edge that goes over the trans is about 3" thick.
Hotrodz of Dallas
Post  kevin924kevin on Fri Mar 02, 2018 4:01 pm
Thank you again, but how thick is at at the outer edge? I have found a tank in Canada and the section of the floor that i need, Just want to be sure be for i buy.
Post  Hotrodz of Dallas on Fri Mar 02, 2018 4:04 pm
kevin924kevin wrote:Thank you again, but how thick is at at the outer edge? I have found a tank in Canada and the section of the floor that i need, Just want to be sure be for i buy.
4 3/4"
Hotrodz of Dallas
Post  kevin924kevin on Fri Mar 02, 2018 4:07 pm
Hey thank you we talk a lot what do i call you?. I very much appreciate your help.
Post  Hotrodz of Dallas on Fri Mar 02, 2018 4:08 pm
My name is Bob
Hotrodz of Dallas
Post  kevin924kevin on Fri Mar 02, 2018 4:13 pm
Thank you Bob, a pleasure to meet you. Have a great weekend.
Post  V8it on Sun Mar 11, 2018 9:56 pm
Thanks men, Great projects, pictures, and information.
I'm rebuilding an Lt1 in my 944, more HP, still a rush.
V8it
