New convert under way
+48
superman22x
turbobob924
RestomodCorvettes
chrenan
iamgod
944_GASM
Hotrodz of Dallas
racertomtom
sparkydog
matt889
HorizonblueDK
crowstyle
pa951
ScottM1A
Slpr948
erioshi
blown 9442
Robb Northrup
Gutterboy
bluejk09
cjbcpa
eclou
kelleysj
Insulator
skywalker01
applebit
MillsMotorsport
suboptimalfit
a951
Dan J
laptop_geek
singleslammer
52 posters
Page 24 of 31
Page 24 of 31 • 1 ... 13 ... 23, 24, 25 ... 27 ... 31
Re: New convert under way
Thank you for the info.
kevin924kevin- Posts : 927
sharkey wrote:check out vibrant performance products, they make all the aluminum bends and couplers, clamps, etc all the way to 5"
Thank you.
just an update. Almost all my parts i have ordered are waiting at the boarder. just waiting on two items to arrive. Then the fun begins.
So any body here cut of the front of the car just in front of the shock towers and replaced with tubing? I have this itch to do a tubular front end for rad mounting and body mounting. Any thoughts?
kevin924kevin wrote:So any body here cut of the front of the car just in front of the shock towers and replaced with tubing? I have this itch to do a tubular front end for rad mounting and body mounting. Any thoughts?
Gets done a lot on race cars. Cut off and plate the front of the factory frame rails. Then weld the tubular front end to tat.
Nice, any pics you know of?
Here are some differeent cars to give you an idea.
Bloomin awesome. Thank you very much.
You are very welcome
ordered my fuel filter kit and my 930 CV kit from Emphi. Next is to do the fuel line from tank to motor. Going to do braided of some sort and fancy fittings. Now i need to look at muffies.
Check out Spintech mufflers. I use them on everything I build.
Will do. Appreciate all the info.
Well this Sat will be xmas for me. Heading to the border to pic up my bounty of parts. I look forward to seeing my rims in person. 11" rears x 19"
[url=https://servimg.com/view/16176565/272][You must be registered and logged in to see this image.][/u
These fit real nice. Came with lug nuts, front spacers, porsche center caps and valve caps. 40 rear 45 front for offset.
well started looking into my clutch pedal. I will have to mod my old or my new pedal. After looking at it i think i will mod the new one. I will have to cut of the bracket that's welded to the pedal as this hits my steering mount and allows no pedal movement. The joys of working with a 78 924.
a very Merry Christmas and a Happy New Year to all.
kevin924kevin wrote:[You must be registered and logged in to see this image.]
DAMN!!!!
is this a good damn or bad?
kevin924kevin wrote:is this a good damn or bad?
MOst assuredly good. That's going to look awesome.
wish i could have that much wheel under my car. looks wicked
sharkey- Posts : 713
SHARKEY - what is that engine you are swapping in?
RestomodCorvettes- Posts : 5
» Do or Don't convert with L83 motor?
» Convert 1986 to 1987+ Offset
» Convert 944 LT1 Swap to LS Swap
Page 24 of 31
Yesterday at 9:56 am by ndog52
