New convert under way
+48
superman22x
turbobob924
RestomodCorvettes
chrenan
iamgod
944_GASM
Hotrodz of Dallas
racertomtom
sparkydog
matt889
HorizonblueDK
crowstyle
pa951
ScottM1A
Slpr948
erioshi
blown 9442
Robb Northrup
Gutterboy
bluejk09
cjbcpa
eclou
kelleysj
Insulator
skywalker01
applebit
MillsMotorsport
suboptimalfit
a951
Dan J
laptop_geek
singleslammer
52 posters
Page 23 of 31
Page 23 of 31 • 1 ... 13 ... 22, 23, 24 ... 27 ... 31
Re: New convert under way
Use the Bosch 044 pump. It will work great.
I use stock front turbo calipers in the rear with the big black fronts. I use the Porsche master cylinder and the 928 pressure valve that screws into the master cylinder. This has always worked perfect.
Thank you is the valve the 5/18. Any body have front 951 Calipers they want to sell? Do these need shims to fit?
kevin924kevin- Posts : 927
I only know the Porsche part number, 928 355 305 02 for the pressure valve.
The calipers will need spacers. Porsche part number 999 025 131 01. I don't know the thickness of them.
Thank you.
New Bosch 044 300 LPH pump ordered.
Awesome
so spent more money today. New starter , brake res, New brake pressure reg, New fuel pump mount, New crank shaft sensor , New 3 Row rad , axle stubs and seals
What radiator did you get?
Its from online cool. 3 row 3 year warranty direct fit for porsche. They say 30% better cooling than a stock 944 turbo rad and can support up to 550 hp and it was a good price. I will deal with a nice shield and fan. Whats the general concensous 2 fans or 1 big one?
2 fans because a single fan sticks out to far and hits the water pump shaft.
so the stock 2 fan is good or aftermarket?
If your radiator is a direct fit replacement, then you might be able to use the stock fans. I mostly use TPC radiators and they use an aftermarket fan setup
Y i hear ya. I will delve into the world of fans a see what i come up with.
Whats the website for the radiators?
i'm not finding what you said.
Well spent more money today. I bought all auto meter gauges speedo, tach,oil, volt,water,fuel, and a new clock. There are more i want, but this will allow start up. Speedo and tach are 5" the rest are 2 7/16" the pro comp ultra light units.
Hi all, can someone tell me how many cfm the stock fans pull vers what cfm TPC sells. There is a nice unit online that pulls 2750 cfm twin 11" blade balanced and in a nice shroud that will fit perfect.
TPC's fans are 850 cfm each. I can't find any info on stock fans at all.
What brand is the fan and shroud kit you found?
Y ai hear [You must be registered and logged in to see this link.] I spent 2 hours to find no info on factory fans.
so thats one unit and hears another.
Both units will fit perfect and have a lot of cfm.
So i bought the unit with 2780 cfm that comes with the relay set up. I also bought a pair of front 951 calipers for the rear of my car from a forum member hear so that will wrap up the break system.
so where does everyone buy there alum for fresh air intake systems? I have looked at a bunch, but most are 3" i need a complete 4". Any thoughts.
check out vibrant performance products, they make all the aluminum bends and couplers, clamps, etc all the way to 5"
» Do or Don't convert with L83 motor?
» Convert 1986 to 1987+ Offset
» Convert 944 LT1 Swap to LS Swap
Page 23 of 31
