New convert under way
+48
superman22x
turbobob924
RestomodCorvettes
chrenan
iamgod
944_GASM
Hotrodz of Dallas
racertomtom
sparkydog
matt889
HorizonblueDK
crowstyle
pa951
ScottM1A
Slpr948
erioshi
blown 9442
Robb Northrup
Gutterboy
bluejk09
cjbcpa
eclou
kelleysj
Insulator
skywalker01
applebit
MillsMotorsport
suboptimalfit
a951
Dan J
laptop_geek
singleslammer
52 posters
Page 15 of 31
Page 15 of 31 • 1 ... 9 ... 14, 15, 16 ... 23 ... 31
Torsion Tube
Well progress on the torsion tube is moving along. It's all layed up and tacked. I will pull the unit out tonight to make the welding a lot more simple. Once that is done, it will be time to cut out the center and fab the plates. If all goes well it should be completed by mid next week. Following that it will be time for final fitment of the other cross member and tack that in, lay up the balance of the cage etc, and weld. once that is done I will set the motor and trans back in to finalize the trans mount.
kevin924kevin- Posts : 927
Re: New convert under way
Incredible project
Don't think I have ever seen so much effort being put into a 924! But great to see that after several years, you still keep working
HorizonblueDK- Posts : 42
CAR
thank you. I wish my time was better, but raising a family and running a business takes a lot of my time. My goal is to have it sitting on four wheels and running by June.
Still one of my favorite builds to watch. Great job Kevin.
The handling should be incredible with the more weight moved rearwards and wider tires.
Car
Thanks Rob, I will be needing your services hopefully soon for the axles.
I'm still curious what the actual/ideal length will be once your trans is set. You may get lucky and be able to use the C5 axle shafts. Remember, you can trim them down some.
Axles
Rob, that wont be the case. I have had the C5 axles in place with the trans sitting were it needs to be and they stick out into the bearing area of the trailing arms. Now in saying that I don't no how much they can be shortened. They appear hollow but I am going to check that out.
Throttle pedal
I said I would post a pic of my DBW gas pedal.
axles
Did some reading today and the C5 axles are solid, so should be able to shorten and have new splines cut in for the 930 CV joint I would think, but I will confirm that hear with my machine shop.
What is your best guesstimate on what the lengths will be end-to-end?
axles
Rob, I will measure the vette axles and provide a guestimate.
It would be where the Tri-lobe sets normally to the CV adapter
axles
Rob my best guess right now would be 18 1/2" the vetted axle is approx 21 1/2" it sat flush plus or minus to the face of the outside edge of the trailing arm. The depth inward to where the axle will sit is about 3 1/4".
Do you have any idea on how many hours you have spent on this project?
The time spent is well worth it when you can say you own/drive one of the baddest 9's on the planet.
Kevin, did that 18.5" dimension account for the CV adapter location?
I will be cutting a set of axles soon for another 928 Z06 trans swap and I can trim a set of those if I have to as they are about 19"
axles
Rob I will have the unit back in the car next week and will confirm length. Much appreciated.
hours
As far as hours go to many. But the r and d takes a lot of time.when I am done I figure with all parts and supplies needed and working on it 8 hours a day you could do this swap in a couple of weeks or less.best guess on hours would be 300 plus.
Yes, the R&D process takes a lot of time. Bolt on and go projects are much easier. I don't know how much time I spent on my straight six project, didn't keep track of time. But nothing was bolt on and go on that project. Well, the engine could be bolted directly to the bell housing, but apart from that, every bit had to be special fabricated.
I'm working on a 25 foot boat, which I'm restoring from A-Z and making changes here and there. That project started 10 years ago. Until now I have spent more than 3300 hours on that (write down every day how much work has been done). When I started that project, I never expected it to be that comprehensive. But well, projects takes time......
Torsion Tube
Step one of my torsion tube is done. I will post some pics on Friday.
Torsion Tube
Torsion Tube
Torsion Tube
Well this is step one. Now to remove the middle section and plate.
Torsion Tube
Torsion Tube
» Do or Don't convert with L83 motor?
» Convert 1986 to 1987+ Offset
» Convert 944 LT1 Swap to LS Swap
Page 15 of 31
