» Lighten clutch pedal feel?
January 2019
78910111213
14151617181920
21222324252627
28293031
New convert under way
Page 2 of 27 Previous  1, 2, 3 ... 14 ... 27  Next
My car 1978 924
Post  kevin924kevin on Mon Mar 21, 2011 3:53 pm
This is the start of the project.All non needed tin gone.
Front end etc
Post  kevin924kevin on Mon Mar 21, 2011 3:56 pm
You can see in this photo the front end parts. You can see the new rear TT quartes, and suspension parts.
More photos
Post  kevin924kevin on Mon Mar 21, 2011 4:12 pm
Hello all, i will take a bunch now that i can post. Thanks to all for the answers provided.
Re: New convert under way
Post  laptop_geek on Mon Mar 21, 2011 7:57 pm
Wow, looks very sharp. Great job. Now just get the engine in there!
laptop_geek
old stuff
Post  kevin924kevin on Thu Mar 24, 2011 7:39 am
[You must be registered and logged in to see this image.] Old rear suspension out
engine bay and hoop
Post  kevin924kevin on Thu Mar 24, 2011 11:32 am
Front engine bay. You can see the custom bent hoop to allow the new front end.Next to remove is the front cross piece. There will be a ton of room upfront.
old motor mounts
Post  kevin924kevin on Thu Mar 24, 2011 11:34 am
You can see where the 924 motor mount where located.I have made steel plates to reinforce this area from the bottom of the cross member area up on to the frame rails.
hoop
Post  kevin924kevin on Thu Mar 24, 2011 11:36 am
[You must be registered and logged in to see this image.] Just another shot of the front support hoop and the space that will be fild with a 3 core aluminum rad.
frame rail
Post  kevin924kevin on Thu Mar 24, 2011 11:37 am
Post  v8carreragts on Thu Mar 24, 2011 9:30 pm
Nice! I aways thought the 911 parts would look good. Not after I bought my first 924 I thought about using late 70's 930 slope nose parts.
Post  kevin924kevin on Fri Mar 25, 2011 11:55 am
I agree i think the 930 slant nose would look really sharp.
brakes
Post  kevin924kevin on Fri Mar 25, 2011 11:57 am
In this photo is the rotors for the big brake upgrade.
wheel well
Post  kevin924kevin on Fri Mar 25, 2011 12:02 pm
This is where my car is different from the 944. You can see where my cross member attaches.
The drop is part of the frame.
Post  87-944S on Fri Mar 25, 2011 6:57 pm
I have the same brakes, they look great, I'm looking forward to trying them out soon.
brakes
Post  kevin924kevin on Fri Mar 25, 2011 7:07 pm
Thank you , i cant wait
running gear
Post  kevin924kevin on Fri Mar 25, 2011 7:11 pm
Question, has any one graphed the complete drive line from the vette, suspension and all? just a thought.
Post  v8carreragts on Fri Mar 25, 2011 10:58 pm
There is a 944 running with the torque tube and rear transaxle and suspension in a 944. His user name is porvette
[url][You must be registered and logged in to see this link.] [/url]
user racer
password racer
corvette trans
Post  kevin924kevin on Thu Jul 28, 2011 10:36 am
Hello all, have been researching the corvette transaxle. Has anyone shortened a porsche torquoe tube. I found a nice custom set of rails to support the corvette transaxle. Has anyone cut out the center section of the torsion tube. It appears, with the center removed the corvette transaxle will work. Any thoughts or info would be much appreciated. XS-chop read one of your blogs on a different form, and you where talking about the same idea, any further developments, suggestions. Thanks all in advance for any info.
Post  v8carreragts on Thu Jul 28, 2011 12:01 pm
I know that there is someone that cut the end off of his torque tube shaft and welded on a GM piece. There are also a few that have cut the center out to the torsion tube. One to fit a Small Block Chevy and 930 transaxle in the back seat and the other (that I know of) cut the center out and used a turbocharged AUDI 5 cyl., a Supra trans and rear diff.
Post  xschop on Thu Jul 28, 2011 12:19 pm
It CAN be done. You'll have to U-channel the Torsion Tube and that is actually not difficult to do if you have welding skills. Amazingly the output shafts of the C5 differential will set only 0.375" aft of where the factory ones are set. I've measured everything. I can honestly say now that the 951 trans R&P can handle the abuse of the 5.3 and you probably need to be pushing 450 rwp to warrant the C5 drivetrain. Also the C5 output shafts can have adapters made to stick on the Porsche axles.
Post  xschop on Thu Jul 28, 2011 12:29 pm
And if you are absolutely serious about this, I will build the axle adapters when the time comes. I have a C5 differential in the shop but no output flanges and I know the factory axle dims (85.5-up) to the thousandth Wink
Thank you all
Post  kevin924kevin on Thu Jul 28, 2011 3:04 pm
Thanks guys the info has helped me make my choice. The car will be a daily driver, but i want some fuel savings on the hwy. My torsion tube is all redone and all my brake stuff is new, so i'm glad i can still use these parts The motor is a crate LS3 with stage 2 cam 480hp ad 10% as per gm = 528 HP.Would you happen to no how wide the vette unit is at the point of the torsion tube. I have to do new bearings in my T tube so cutting is good timing. I am going to use Constantines bearings. When i need axles i will be callin, any other info or ideas are much appreciated. Again Thank you.
Torque tube thought
Post  kevin924kevin on Thu Jul 28, 2011 3:06 pm
Has anyone change the tube to aluminum? just a thought.
Post  xschop on Thu Jul 28, 2011 3:08 pm
Just use the ENTIRE C5 drivetrain. You can even mod the shifter location easily.
Torque tube
Post  kevin924kevin on Thu Jul 28, 2011 3:15 pm
I no what your saying but the C5 tube is 8" and would require deeper surgery to the floor pan and tunnel. But i guess if i am cutting away the back floor pan to allow the transaxle to sit approx where factory did, whats a little more cutting.
