86 944 sbc exhaust ???? EmptyYesterday at 11:51 am by geegeesbits@gmail.com
86 944 sbc exhaust ???? EmptyMon Jan 27, 2020 2:27 pm by Porsche951toLS3
86 944 sbc exhaust ???? EmptySun Jan 26, 2020 4:51 pm by j7wolfe
86 944 sbc exhaust ???? EmptySat Jan 25, 2020 6:42 pm by kevin924kevin
» Pedal Assembly - Which one?
86 944 sbc exhaust ???? EmptyTue Jan 21, 2020 5:27 pm by Hotrodz of Dallas
86 944 sbc exhaust ???? EmptySat Jan 18, 2020 7:15 am by Rothaus
86 944 sbc exhaust ???? EmptyThu Jan 16, 2020 6:51 am by 87944turbo
» 82 924 with AUX Audi V8.
86 944 sbc exhaust ???? EmptyThu Jan 16, 2020 2:11 am by Golten1986
86 944 sbc exhaust ???? EmptyTue Jan 14, 2020 2:48 pm by Gumby
86 944 sbc exhaust ???? EmptyTue Jan 14, 2020 6:43 am by 87944turbo
January 2020
6789101112
13141516171819
20212223242526
2728293031
86 944 sbc exhaust ???? Empty 86 944 sbc exhaust ????
Post  smither944 on Tue Feb 01, 2011 6:50 am
Hi Im curently doing a sbc changeover in my 86 944,the only thing that is throughing me for a loop is the exhaust. is there any easy mods for headers or manifolds?? confused
smither944
smither944
86 944 sbc exhaust ???? Empty Re: 86 944 sbc exhaust ????
Post  Admin on Tue Feb 01, 2011 8:49 am
First off, welcome, second If you want good answers post in the correct topic area.
As far as exhaust setups, you can use Sanderson Headers or have custom made headers built.
Post  v8carreragts on Tue Feb 01, 2011 11:15 am
Chevy Corvette Rams Horn manifolds fit. You just need to be certain that you get the ones that both dump straight down. Some of the drivers side turn towards the rear at the outlet and those do not work.
Post  laptop_geek on Tue Feb 01, 2011 6:19 pm
The only thing that I know of that will fit are shorty headers. If you want long tubes your going to have to go custom. If you do decide to do that there are a couple guys on here that can help you out with that (I'm doing that now).
laptop_geek
laptop_geek
Post  bluehellfire666 on Tue Feb 01, 2011 7:28 pm
i used Patriot tight tuck shorties on my LT1, they're round ports so they should bolt up to your sbc. I cut the collector flanges off and welded straight to them to give myself more room, you'll still need to beat on your frame rails and maybe the side of the header just a bit, but it should fit nicely
bluehellfire666
bluehellfire666
Post  smither944 on Tue Feb 01, 2011 8:02 pm
Thank you so much for the info. I will work on where to post for next time. Is the LT1 exhaust the same as a small block??? I have never played with LT1 or LS1. Will shorty headers clear the steering shaft?? I didn't think modifying cast headers would last.
smither944
smither944
Post  Dawgz83948 on Wed Feb 02, 2011 9:02 am
smither944 wrote:Thank you so much for the info. I will work on where to post for next time. Is the LT1 exhaust the same as a small block??? I have never played with LT1 or LS1. Will shorty headers clear the steering shaft?? I didn't think modifying cast headers would last.
IIRC the LT1 is the same. The LS1, well, not so much. I'm using the Pacesetter headers from a 96 Vette. Cut the collector 1" and everything welds up.
Post  bluehellfire666 on Wed Feb 02, 2011 9:06 am
LT1 and SBC headers have the same bolt pattern. LT heads had a D shaped exhaust port in the head, whereas most SBC heads had a O shaped exhaust port. With the right header gaskets everything will bolt up fine and seal up fine, and anyway most headers are made for sbc's and then are transferable to the D style LT head, so most will be a perfect fit for you straight out!
bluehellfire666
bluehellfire666
Post  smither944 on Thu Feb 03, 2011 6:12 pm
So the LT1 style center cylinder exhaust ports are close together like a SBC? I have done a little bit of looking for ram horn style manifolds. I need the ones that dump straight down, not curved? Does anybody know of a cheap shortie block hugger header that works? Thanks so much for your time I am learning quite a bit.
smither944
smither944
Post  v8carreragts on Thu Feb 03, 2011 6:40 pm
LT1
Gen 1
The manifolds that fit
There's a block hugger listed here somewhere that fits as well.
Post  bluehellfire666 on Thu Feb 03, 2011 11:27 pm
i'm pretty sure those are the ones i used...the 150 dollar set is just plain steel, not ceramic coated. And you'll probably have issues with the collector flanges, because they add at least 1/2 an inch on each side that you really need. Other than that they should bolt right up!
bluehellfire666
bluehellfire666
Post  Admin on Fri Feb 04, 2011 8:29 am
As I have said in my previous post, Get the Sanderson headers that fit! They bolt right up with no fab work needed.
Post  Dawgz83948 on Fri Feb 04, 2011 12:15 pm
Or something like the pacesetters that I'm using.
Post  smither944 on Sun Nov 13, 2011 7:20 pm
Do you happen to have a sanderson part number?
smither944
smither944
Post  Admin on Sun Nov 13, 2011 9:01 pm
CC2 and CC90 one of each.
86 944 sbc exhaust ???? Empty cc90
Post  luginbuhlj on Tue Nov 29, 2011 12:02 am
I'm glad I stumbled across this! For 255 bucks yea can't beat that ... summit has some 100 shorties but idk how long it lasts since its not coated.
luginbuhlj
luginbuhlj
