Selling off my stock clutch parts and RH clutch disc
Selling the clutch package with the stock LS1 flywheel and pressure plate and the RH clutch disc with 23 splines. In total this has 4 weeks total driving, not even 500 miles on the clutch.
I have had no problems with this setup during the few drives I did and am selling off since I have the new Spec setup, All that is needed is the 6 crank bolts to attach the flywheel to the crank.
I would like 150.00 for the complete package. I will not part the setup.
The unit weighs in at right under 50lbs once you add the box weight and packing.
