GT Hood location
GT Hood location
Ok I bought a GT hood scoop and wanted to keep it looking like an orginal GT (atleast the scoop).
Anyone have the dimensions (placement) on where the GT hoodscoop was located?
ffmedic- Posts : 103
Re: GT Hood location
I have them. I will need ot look for them though. I have a paper pattern. AIR used to send it whith the scoop so you can locate it properly. (maybe they still do?) Anyway, I still have it somewhere. I coule also measure my hood. Give me a day or two.
v8carreragts- Posts : 332
Found the pattern. The front edge of the scoop is 10 3/4" from the front edge of the hood. On the right side (passenger side) the closest part is 5/8" from the formed line on the hood.
v8carreragts wrote:Found the pattern. The front edge of the scoop is 10 3/4" from the front edge of the hood. On the right side (passenger side) the closest part is 5/8" from the formed line on the hood.
Yes but how far from the edge of the hood from the passanger side?
need length from side and front :p
The passenger side is 5/8" from the crease in the hood. There are two creases, one on each side about 8" or so from the sides of the hood.
Thanks much appreciated .v8carreragts wrote:The passenger side is 5/8" from the crease in the hood. There are two creases, one on each side about 8" or so from the sides of the hood.
You're welcome! I was worried about getting mine correct too. Even after I bought it and was looking at the pattern that came with it and wanted to be sure. So I looked through the 100's of GT/GTS photos and found one that I thought I could use to scale the scoop. It actually came out exactly to the same measurements.
