» 5.3 conversion on 88 Turbo
Today at 11:00 am by kevin924kevin
Today at 6:37 am by Patb
» Clutch Issues - HELP!!!
» Hydroboost Lines from TPC
» 1984 Gen IV 5.3 Swap
» Dry Sump Oil Pan Fitment
May 2018
78910111213
14151617181920
21222324252627
28293031
Wilwood 330mm Big Brake kit for NA cars
Page 2 of 2 Previous  1, 2
Re: Wilwood 330mm Big Brake kit for NA cars
Post  xschop on Mon Sep 05, 2011 10:31 pm
The Ebay rotors are good to go. I've still yet to burn up the R1 concepts rotors I got and the Advance Rotors brand are O.K. as well....
The only thing you need to do is get 2ea 1/8-27 NPT to AN adapters if you have AN braided lines. My car already had them and was a simple switch of caliper end fittings. I bought another large stick of billet and will be churning out centering rings for some 928 modders and a couple GT3 racers. They will fit the 355mm Cayenne rotors as well Laughing
Hey Spence, those look great. How much clearance side and top and what is the offset? I'm sure the 928S guys will be interested. Thanks
Post  xschop on Tue Nov 15, 2011 3:13 pm
I've got two sets of these adapters/centering rings left. It may be Jan. before I produce any more of these...
$209 Shipped US-48 Only.... Just PM
Mo wheels
Post  xschop on Fri Feb 17, 2012 6:35 pm
Got a reply back from Australia on another wheel combo......
17 inch sports classic wheels,-7 inch 55 offset, Wilwoods fit A1 (wilwood logo removed)
3mm caliper to rim clearance at the "X"
http://forums.rennlist.com/rennforums/attachments/928-forum/608225d1329351093-wilwood-calipers-cayenne-330mm-rotor-swap-porsche-brakes-078.jpg
Post  bordin34 on Tue Feb 21, 2012 10:37 pm
These will not work on a 1986 N/A correct?
bordin34
Post  xschop on Wed Feb 22, 2012 4:57 am
Not on an 86 NA unless you have a custom hub.
Post  xschop on Wed Feb 22, 2012 9:40 am
Bordin, Now that I think about it, The Wilwood Dynapro will fit an 86 951 300mm rotor on the 86 NA spindles/Hubs and I will be mocking those up soon.
Post  bordin34 on Wed Feb 22, 2012 11:29 am
Awesome, I've been wanting to do a brake conversion since I bought the car but wanted to keep early offset so I can run my 16" Fuchs.
bordin34
Post  HandofTron on Tue Sep 03, 2013 6:40 pm
Still doing wilwood kits?
HandofTron
Post  scryfst on Sun Nov 24, 2013 7:35 pm
Anyone know how I can get my hands on a set of these adapters? Or the prints?
I'm also interested in the ls430 swap, and the adapters. Or prints.
I have to say, I've use xcshop's RX7 swap and it works great. Had the adapters milled locally from posted prints.
THANKS XCSHOP!!!
I've yet to post enough to PM people , otherwise I'd PM him.
scryfst
http://www.widerstandsfahig.com
Post  DJ. on Mon Nov 25, 2013 11:19 am
I pmed you or email me back , I have a set available.
d.jtc@hotmail.com
DJ.
Post  HandofTron on Fri Nov 29, 2013 1:31 am
wrong thread
HandofTron
Post  xschop on Fri Nov 29, 2013 2:56 am
If you,did not get the 1.62 piston Superlights then you'll have issues with factory MC.
Post  applebit on Fri Apr 18, 2014 1:55 pm
Please tell me you are still fabricating these/have a pair left! I have the 1978 Porsche 924 that was converted to 944 brakes, turbo twist 2 wheels as well. The car is in the shop at the moment and we are trying to figure out the best route and this appears to be it!
I'm sure you are familiar with the car:
applebit
http://www.bmcautos.com/
Post  xschop on Sat Apr 19, 2014 1:33 pm
Completely out of the Superlite adapters. I will debut the "Bigger Black" adapters and send you a set out with centering rings for the Cayenne 330 rotors.
Post  PHillary on Wed Jan 27, 2016 11:38 am
Do you have any more wilwood adapters for NA cars or can you make me a set still?
PHillary
