Today at 7:52 pm by matt889
» New here needing help
Today at 3:45 pm by sharkey
» 5.3 conversion on 88 Turbo
Yesterday at 11:00 am by kevin924kevin
Tue May 22, 2018 10:36 pm by mryan318
» Clutch Issues - HELP!!!
» Hydroboost Lines from TPC
» 1984 Gen IV 5.3 Swap
May 2018
78910111213
14151617181920
21222324252627
28293031
87-up Turbo Spindle
87-up Turbo Spindle
Post  xschop on Wed Jan 19, 2011 2:56 pm
I need an 87-up Turbo spindle (NON 86T)
Doesn't matter which side, I only need one for mock-up of a few different Big Brake kits I'm working on. There will soon be adapters to mount Wilwood Superlites to fit the NA spindles and Turbo spindles. I am also doing the mock-ups to fit the Porsche Brembo Turbo calipers (94mm ears) to the 87-up NA spindle (76mm ears). And when the parts arrive I am also going to build adapter to put 928 S4 calipers (130mm radial ears) on the NA and Turbo spindles as well
Re: 87-up Turbo Spindle
Post  xschop on Wed Jan 19, 2011 4:49 pm
As a heads up there will be adapters for these Wilwoods that put them on 298 x 28 87-88T rotors (fit under 16" phonies) and 304 x 32 (M030) rotors for extreme heat/track use....
Post  Porch on Wed Jan 19, 2011 7:45 pm
Glad to see you're doing this! I haven't priced those calipers lately but i've been saying for a while that the 944 guys need to get away from the "big reds" and "big blacks". These Wilwood calipers are top notch and they cost 1/3 as much!
Post  xschop on Thu Jan 20, 2011 5:37 am
Got that straight, and the pad selection is primo with an area equivalent to the Big Blacks/Reds. Piston size is selectable as well.....
Post  Porch on Thu Jan 20, 2011 9:41 am
Nice, so those are equivalent to a ~41mm piston. The pad selection is what really makes them a steal, though.
Let me know when you get these adapters made for an '87T spindle, and how much you want for 'em Smile
Post  xschop on Thu Jan 20, 2011 7:05 pm
I worked out an adapter to put on a Cayenne front 330mm x 32 x 69 offset rotor on the Early 928 spindle/hub. It would need centering rings like the BoxsterS rotors, but would also fit these calipers and fit under 17's on the 944....just another option to muse.
I need an 87-up Turbo spindle regardless if anyone has a loaner.
