Can anyone post up some clear pictures of relocated coil packs?
I need to relocate the coil packs for the brake master cylinders. I need to see how others are relocating the coils. Do you have to get longer spark plug wires or get into the harness to free up some length?
Re: Can anyone post up some clear pictures of relocated coil packs?
Where are you moving them? I used truck coils, which moves them up on the valve cover, so I got high performance truck wires, which are plenty long enough.
If you use the truck coils a new fuel rail will be needed, right? I thought it would be easier and cheaper to relocate the coils to fit the dual master cylinders. Just exploring my options.
I stacked the rearmost 2 cyl on the driver's side in order to fit the Wilwood MC. I'll post a pic tomorrow.
Dan.
Dan.
Dan J- Posts : 117
Thanks, that would be helpful. Some one here posted a picture of a LS motor in a S10 with the coils stacked but the picture wasn't clear enough to see how it was done.
Ok, a few photos are posted - check out my gallery.
I used a pair of long bolts and nyloc nuts to position the #5 coil (flipped over on it's back) on top of the #7 coil. The stock plug wires only 'just' reach, so I'm using a truck wire for the top #7 coil.
The coil bracket is cut down as well for clearance with the MC.
I hope this helps,
Dan.
I hope this helps,
Dan.
Dan J- Posts : 117
That helps. Thanks, for taking the time to post the pictures and the description of what you did.
What MC are you using?
Dan.
Dan.
Dan J- Posts : 117
I am using Xshop's dual master cylinder mount. I will need to relocate the last two coils or go with the truck coils. If I go hydroboost in the future the coils will have to be relocated anyway no matter if they are the truck or car units. I am leaning toward relocating them to the wheel arch for that reason.
Vorsche944 has some great pictures of the relocated drivers side coils and the brackets in his gallery. I am glad you guys take pictures.
» Wilwood 260-7563 MC - mounting questions
» Coil mounting pictures
» Air intake that will clear latch!!!
