968 LS2/3 progress
968 LS2/3 progress
With Eric's help I finally figured out how to host an image here! Here is a picture of my project it is running and the suspension and brakes are done. I need to install dash/interior and then put the body back together.]
[img][/img][You must be registered and logged in to see this image.]
968ls1- Posts : 47
Re: 968 LS2/3 progress
Is it an LS2 or LS3?
Forged 404 LS2 bottom end with LS3 heads and intake.
968ls1- Posts : 47
nice! I like your cold air, it looks like a 968 offers more room than a 944, or have you just reworked the front to make it that way?
Radiator has been tilted forward to allow room for the 4" intake pipe. I have done similar modification on 2 944 conversion I have done but they were LS1 and used a 3.5" intake pipes. The windshield washer reservoir has to be eliminated on a 944 to allow room for the pipe. The hood latch location on the 944 is also a limiting factor for room in front of the engine.
968ls1- Posts : 47
Thats what I was thinking about my setup in the 944 with the limiting factors.
What is your opinion on the air filter setup, run it like that or would it be better for a straight over to the intercooler area like Doc and others are doing now? The whole argument on bent vs straight intake
If you can go straight and eliminate any bends thats what I would do. The reason I did not do that is my radiator is 18" tall and would not allow a straight path. Also with a 92mm throttle body I had to use a 4" pipe to feed the motor which makes it even tighter.
968ls1- Posts : 47
I see, I have a RH radiator which is pretty tall and the support bar sits as low as the cross member of the engine. So I have been thinking of alternative routes.
Thanks for your input. Keep up the great swap.
how did you get that nice finish on the intake?
eclou- Posts : 102
I used Duplicolor wheel paint out of a can.
968ls1- Posts : 47
