E-Brake Cables
E-Brake Cables
Does anyone know if the late (85.5 and up) e-brake cables can be used on the early cars? They look the sane in pictures but I haven't been able to compare the two side by side.
v8carreragts- Posts : 332
Re: E-Brake Cables
i have the same porsche part number for all the 944/951 brake cables . so i would say its the same cable ?
962porsche- Posts : 135
Re: E-Brake Cables
The PET shows 477.609.719.C & 477.609.720.C for the early and 951.424.071.02 & 951.424.072.02 for the late. Also when you look them up online to purchase it shows early and late.
I don't see what could be so different between them. The late ones are less expensive so since i need to buy these I would like to buy the less expensive ones if I can.
Re: E-Brake Cables
i looked it up in my pathways shop estimating guide . the only #'s they offer is the 951 numbers. i can check it when i get to the shop tomarrow . i have the porsche parts look up on disk at the shop .
Re: E-Brake Cables
From PET all the guide tubes and other parts are the same between the two. The big difference I can see is the e-brake handle. The threaded end of the cable is the same thread for both, unless the caliper end is different, I'd say it would work.
Re: E-Brake Cables
i looked in my porsche parts look up and the only thing it gives is the parts numbers that you have with only a drawing to show what the part looks like . i have the cables out of my 84 944 spec race car but we got 30 inches of snow so i can't see what they look like to my 88 944 because that car is out side .
