Early LS430 Caliper set
I'm not swapping to my Lexus Calipers on my S2, so I have a set of early hubs machined to fit the Boxster S Rotors, Boxster S Rotors, Lexus to early N/A adapters, and remanufactured LS430
Calipers. $300.
Calipers. $300.
Dawgz83948- Posts : 603
Re: Early LS430 Caliper set
Don't know how I missed this thread. Are you still wanting to get rid of the konis?
laptop_geek- Posts : 230
Yes. Still have all 4. [You must be registered and logged in to see this link.]
Sold the calipers, but check out the rest of the stuff if you guys need anything else. I also have some decent early interior pieces.
Man, I would LOVE to get that transmission from you... How much to ship it to a buisness address in 27511? I dont care if you send it via Camel as i am in no rush... Need to see if i can fit it in as i am still broke from christmas..
Mark
Mark
Marky522- Posts : 175
Marky522 wrote:Man, I would LOVE to get that transmission from you... How much to ship it to a buisness address in 27511? I dont care if you send it via Camel as i am in no rush... Need to see if i can fit it in as i am still broke from christmas..
Mark
You know the S2 has basically the same same ratio as the N/A transmissions but is stronger, right? It's not a turbo with the V8 friendly ratio. Your rpm's will be in the 3000 range @ 65.
According to the conversion manual
The 5th gear ratio for the:
S2 (AOS) is 0.778,
Early N/A (QM) is 0.7297
Late N/A (5S) is 0.7297
951 (5P) is 0.829
The final drive ratio for the:
S2 (AOS) is 3.875
Early N/A (QM) is 3.8889
Late N/A (5S) is 3.8889
951 is (5P) 3.375
So it looks like the S2 transmission is in class of its own.
I know with my early car I was cruising at 60 MPH and running around 2200 rpm.
S2 (AOS) is 0.778,
951 (5P) is 0.829
S2 (AOS) is 3.875
951 is (5P) 3.375
Brakes are Sold and gone.
Anyone need a good set of 1 year old koni's (complete f&r) for an early car in the reloadable front strut?
» LS430 Big Brake Swap
» Lexus Caliper Adapters--Early cars
» For Sale: NA LS430/Boxster S big brake kit
