» alignment specs
Today at 12:53 am by sharkey
Yesterday at 9:46 am by JSP
» Transaxle rebuild
» Tpc LS adapter plate
Wheel question
Wheel question
Post  cfgioja on Tue Dec 21, 2010 11:49 pm
If I get the 2" front fender and the 4" rear fenders will these be able to fit under the car? I really like the look of them. They have an 18" set too, but they sell the sets in 4. I didnt know if I would need an 18" rear wheel and 17" front or if I could run 17" all around.
FITMENT: Fits stock 4th generation Camaros 1993 - 2002 and stock Firebird & 4th generation Trans Am - 1993 - 2002
MAKE: Corvette
PRODUCT: Z07 Style
WHEEL SIZE: 17x9.5
WHEEL OFFSET: 54mm
BOLT PATTERN: 5-120.65
FINISH: Black With Red Banding
CENTER CAPS: Center Caps are included.
LUGNUTS: Discounted lug packages available 1-866-273-3651
Re: Wheel question
Post  skywalker01 on Wed Dec 22, 2010 6:43 am
I am running 18" rims all the way around and experience minor rubbing on hard turns with the fronts - could be the width. If you want to go the safe route, use 17's all the way around. As always, just my .02; your mileage may vary.
skywalker01
Re: Wheel question
Post  cfgioja on Wed Dec 22, 2010 11:04 am
Also what kind of spacer/ huub adaptor would I need to run these?
Re: Wheel question
Post  skywalker01 on Wed Dec 22, 2010 11:59 am
Very Happy Just so happens I happen to have a set of spacers in the 'For Sale' forum
skywalker01
Re: Wheel question
Post  cfgioja on Wed Dec 22, 2010 2:48 pm
They don't adapt from 5x130 to the 5x120.65 do they?
Re: Wheel question
Post  skywalker01 on Wed Dec 22, 2010 7:38 pm
While I am sure there are some out there that may get you to where you want to be, these only
convert to 5x114.3
Pat
skywalker01
Re: Wheel question
Post  cfgioja on Wed Dec 22, 2010 8:07 pm
I contacted a place today waiting on a reply from them. They make special hub adapters.
Re: Wheel question
