» V8 Conversion Parts
Today at 3:46 pm by lawn_mower
Today at 1:22 am by 964ruf
» PCV routing??
Thu Aug 09, 2018 9:52 am by Rich L.
Thu Aug 09, 2018 9:31 am by chrenan
» 944 conversiobs
Wed Aug 08, 2018 8:40 am by Hotrodz of Dallas
» Drag set up
Mon Aug 06, 2018 11:19 am by Hotrodz of Dallas
Sun Aug 05, 2018 6:40 pm by LSA_944
Sat Aug 04, 2018 11:17 am by acorad
» Mustang hydroboost valve cover clearance
Sat Aug 04, 2018 9:48 am by matt889
» Who uses Mustang MC with Hydroboost in 944 ?
Tue Jul 31, 2018 9:33 am by chrenan
August 2018
6789101112
13141516171819
20212223242526
2728293031
A/C and Heater options
Post  cfgioja on Sun Dec 19, 2010 11:20 pm
So i have been doing some digging and a little research. I have realized that alot of the interior components are old and need redone to a certain degree. I figured the A/c and Heater box was not any different from the rest of that. If we are going to go custom why not go all the way. Installing a new a/c and heater system in the engine bay and hooking it to the old box still is running a chance of the system not working.
I found a couple options I have been eying and didnt know if anyone else thought about this yet.
a/c or a/c and heater setups.
heater only
Some of these systems you can have electric switches instead of cable driven so you can mount your own panel and simplify the Porsche controller. I know brand new that thing cost close to 800.00 and used is about 200-500 depending on the seller and condition and there is no guarantee that it will work for long.
Just fishing for opinions really.
Re: A/C and Heater options
Post  v8carreragts on Mon Dec 20, 2010 10:10 am
There is also Vintage Air. They have the same type of stuff.
Post  ALFAPU on Mon Dec 20, 2010 10:38 am
Also, summitracing.com has their own brand of in-house heating systems. The Summit brand is a little cheaper than Vintage Air or any other heating systems I've found.
This is the same route I am planning to go with my build because the stock heater box weighs a ton, it has a bunch of redundant features and I've never had a heater that worked right in all the 944s I've owned. Here in Seattle we only need air conditioning for maybe two weeks every other year, and I pretty much only use defrost or floor heat in winter; I don't think I'll miss the factory heater box.
ALFAPU
