» Lighten clutch pedal feel?
January 2019
78910111213
14151617181920
21222324252627
28293031
Back Light Panel
Back Light Panel
Post  cfgioja on Sun Dec 19, 2010 11:09 pm
Just finished installing and hooking up the light panel for my rear end. I like how it looks in the day but I am kinda disappointed by the view of it when it has its lights on. The bulbs dont really light up the whole panel, There is no reflectors or anything in it so it is just suppose to do this. Still it is unique and looks good all around.
Re: Back Light Panel
Post  Bluemongoose on Mon Dec 20, 2010 1:56 pm
There was one of these light kits on my 944 when I purchased it .... a long time ago. I removed it about 5 years ago to get a different look at the rear of the car. Also I used a separate light shut off switch to kill the illumination at will.
You could place a reflector in front of the light bulb to evenly distribute the light.
Bluemongoose
Post  cfgioja on Mon Dec 20, 2010 2:00 pm
I was thinking about that, it would mean me taking apart the assembly to place a reflector in on each of teh bulbs.
Post  Arthropraxis on Mon Dec 20, 2010 3:33 pm
Seems like I read a while back there were 2 different qualities of the reflector. One that was better than the other. Is yours more flat plastic or does it have that texture in it like a reflector on a turn signal?
Post  cfgioja on Mon Dec 20, 2010 3:48 pm
the inside of the red plastic is rough like a turn signal.
Post  Arthropraxis on Mon Dec 20, 2010 3:50 pm
Are you using regular bulbs or LED's? The LED's might brighten it up.
Post  cfgioja on Mon Dec 20, 2010 3:51 pm
they are just regular bulbs. I had to make a new harness since the old wire was falling apart. I was thinking about upgrading to an led setup.
Post  Punisher948 on Mon Sep 02, 2013 4:21 pm
I think that if you use LED Tape strips from here (http://www.keepitcleanwiring.com/catalog/Lighting/L.E.D.-Tape). I am considering the same thing. I bought a kit to light the empty panel years ago. Thought it was a neat add on. I think after my conversion is complete I will revisit some things and do some upgrading.
Punisher948
