Self canceling turn signals dont
I'm sure somebody has dug into theirs and can send me right to the problem. Turns signals will cancel after right hand turn but not left hand turn. I have aftermarket hub and steering wheel. Something about a tab in there that gets bent? Anybody run into this? Thanks in advance.
Been cold down here in Florida and i've been driving the Porsche a lot lately. The thing has heat coming out the vents before I'm all the way out of the drive way. Love it.
sbwrench- Posts : 66
Re: Self canceling turn signals dont
On your after market hub, check the pins that are used in place of the original tab on the stock hub. The pins are some times to short, this will cause it to work sometimes and not others. Like left but not right. Or right but not left...............
So is the solution to make a longer pin or is there something I can adjust, strecth, pull?
I had to put in longer pings. They are just roll pins usually and can be pulled and replace very easily. What brand is yours? The last one I did was a Momo brand. You think they would have it right!
Mines a Momo as well. Thanks for the info. I have a bunch of vacation days I need to use up so maybe I can get after it. Testing tires at the newly paved Daytona Speedway next weekend and then no work until 2011! Except for the endless emails and phone calls of course.
My bad. It's a Sparco but probably the same deal.
» Techno Duck's LS1 conversion
» Turn one pump without a reservoir?
» FS: 1986 Porsche 944 Turbo 350 LT1 turn-key
