Weight increase from LT1?
I'm planning an LT1 swap and maybe I'm not using search correctly but I can't seem to get any hits that will tell me how much weight I should expect to pick up due to the motor swap.
Looking to get to better than a 10 lb/hp number at the wheels, which I think should be pretty easy to do. Car will be more or less gutted as it'll be a track car. Probably won't be street legal.
Thanks for any tips, or if you have a suggestion of a better motor to use. Donor is an 87 944S.
NoTheOtherSparky- Posts : 4
Re: Weight increase from LT1?
These values differ all the time depending on options and accessories.... especially the 944 engine....due to the fluctuations in weight due to oil leaks
LT1 dressed = 460 lbs
LS6 dressed = 382 (w/o clutch) 420 (w/clutch)
944 dressed = 366 (dry w/o clutch) 410 (as running)
source: (LT/LS) GMperformance specifications, (944) I've weighed it personally
LT, your 944 dry weight is exactly the same as the official Porsche Spec book says! Your LT1 weight looks about correct as well. The Gen I (iron head) is 550# and the aluminum heads and intake are about 90# lighter.
v8carreragts- Posts : 332
