New Coil Overs arrived EmptyYesterday at 6:12 am by Colibri Green
» NDog52's 1986 NA 5.3 Build
New Coil Overs arrived EmptyTue Mar 26, 2024 6:28 pm by Raymond-P
New Coil Overs arrived EmptyTue Mar 26, 2024 3:29 pm by Blaizefed
New Coil Overs arrived EmptyTue Mar 26, 2024 1:30 pm by Raymond-P
New Coil Overs arrived EmptyTue Mar 26, 2024 8:49 am by 948
New Coil Overs arrived EmptyWed Mar 20, 2024 11:52 pm by Raymond-P
New Coil Overs arrived EmptyWed Mar 20, 2024 1:17 pm by Rob44
New Coil Overs arrived EmptyTue Mar 12, 2024 3:22 pm by dcoutofstep
New Coil Overs arrived EmptyTue Mar 12, 2024 2:10 pm by dcoutofstep
New Coil Overs arrived EmptyTue Mar 12, 2024 12:12 pm by ndog52
+2
6 posters
New Coil Overs arrived Empty New Coil Overs arrived
Post  cfgioja Fri Feb 25, 2011 1:16 pm
Wanted to show what Ground Control is pushing out for coil over setups for the 944.
New Coil Overs arrived Img_1310
It has assisting springs for the rear to allow the torsion bar to stay in, if I decide later to remove the bar I can just up the spring rate in the rear.
Camber plates and Koni struts.
Total package shipped at 45lbs, so its not too bad for a sport suspension setup to weigh in at.
Once I finish the engine build I will get these installed and let you know the feel. I am going to look up rear suspension install instructions. Let me know if you have any advice.
New Coil Overs arrived Empty Re: New Coil Overs arrived
Post  Dawgz83948 Fri Feb 25, 2011 1:55 pm
Yup, I finished mine a month ago or so. I didn't opt for the camber plates since I already had a set that, although not adjustable, just as nice. The rear is really easy, I removed the old shocks, set the initial height to 1.25" from the top and installed it. I had to adjust the rear a little later, but thats real easy. You will have to load up the rear suspension in order to get the new ones on. (all rear shocks require this though)
https://944hybrids.forumotion.com/t1107p15-90-cab-swap Page 2 has some pics of the suspension.
cfgioja wrote:Wanted to show what Ground Control is pushing out for coil over setups for the 944.
Post  Bluemach1 Fri Feb 25, 2011 3:29 pm
What did you end up paying for that set up? Ground Control is about 10 minutes away from my house!
Bluemach1
Post  Dawgz83948 Fri Feb 25, 2011 3:33 pm
Bluemach1 wrote:What did you end up paying for that set up? Ground Control is about 10 minutes away from my house!
I paid $1200 for my setup, which was for the rear konis w/ springs, front coilover kit w/ springs, and the cut-n-gut front Koni adjustables. I think the adjustable camber plates are in the $250-$300 range.
Post  xschop Fri Feb 25, 2011 3:44 pm
What is the compressed and extended I2I length on those rear coilovers?
Post  Dawgz83948 Fri Feb 25, 2011 4:06 pm
What spring rate did you get for the rears.
Post  cfgioja Fri Feb 25, 2011 4:38 pm
I'll have to post the invoice for u guys tomorrow, taking my wife out for her bday. I spoke with Jay and gave him all the info on my car and he helped with the spring selections. I have bad memory so I forgot what it is. It is on the invoice though.
Total with this setup ran just over 18k, they have three different levels for the setup 12k being the lowest if I remember correcly. Checkout their site for specifics.
Post  Dawgz83948 Fri Feb 25, 2011 4:57 pm
cfgioja wrote:I'll have to post the invoice for u guys tomorrow, taking my wife out for her bday. I spoke with Jay and gave him all the info on my car and he helped with the spring selections. I have bad memory so I forgot what it is. It is on the invoice though.
Hope fully not 18k (18,000) but 1800 right?
Post  docwyte Fri Feb 25, 2011 9:17 pm
In for rear spring rates too...
Post  robstah Fri Feb 25, 2011 9:46 pm
Not to be a naysayer or anything, but Koni technology is "slow" at best.
Post  docwyte Fri Feb 25, 2011 9:52 pm
Never had an issue with the Koni's. They're good shocks and to get better you end up spending a huge amount of money for Motons, Ohlins or Penskes.
Post  cfgioja Sat Feb 26, 2011 12:49 am
Ya sorry 1800.
They may not be the best but 90% of this will be used on street, so I think for that little bit of track days they will be good.
Post  cfgioja Sat Feb 26, 2011 9:53 pm
Here is my invoice for the setup.
New Coil Overs arrived Ground10
Not exactly sure if this is correct but I did some searching and found out that the part numbers give you Height, diameter, and spring rates all in metric. Got to love that. So to convert, divide by .0179 and wallah
if the front is 7.7 kg-mm the ft-lbs is 430 ft-lbs
the rear is 1.75 kg-mm the ft-lbs should be roughly 100 ft-lbs;
(which sounds really familiar since I had a long conversation in regards to the torsion bar and the options around the rear suspension. Jay told me that this should be fine but if I decided later that I needed to remove the torsion bar I can just up the spring weight since I already have the coil-over kit installed now.)
Here is the site for Ground control to see all the kits they offer for the 944;
http://www.ground-control-store.com/products/category.php/CA=170
my sources;
http://www.rx7club.com/showthread.php?t=326217
http://www.clubwrx.net/forums/suspension-wheels/116663-kg-mm-lbs-conversion-ie-spring-rates.html
