» Tpc LS adapter plate
» Headers, headers, HEADERS!
Dropping a 5.7 lt out of a camaro advice
Post  storch on Fri Dec 03, 2010 9:39 am
I think I might have found a decent deal on a 94 5.7, complete with harness, etc., 120K for a few hundred bucks.
It's local so no delivery. The only downside is that I'd have to pull the engine myself and the car is parked out in a field.
How tricky/complicated would it be to do?
I've got a cherry picker, heavy duty flat hydraulic cart, and some normal size jack stands, that I could bring to the site in my old pickup.
What other tools would I need? Does the F body use metric or sae bolts (just so I can bring the correct hand tools)?
I would think I'd have to drain fluids, disconnect exhaust, ac, hoses, wiring, drive shaft, etc. Then its a matter of unbolting the front suspension? I've heard that if I disconnect the front suspension (K frame?) and lift the chassis high enough with the cherry picker, the whole drive assembly could pull out.
And where's the ecm located?
What do ya guys think?
storch
Re: Dropping a 5.7 lt out of a camaro advice
Post  944convert on Fri Dec 03, 2010 12:53 pm
I think these may help for a start:
-Tom
Post  storch on Sat Dec 04, 2010 6:12 pm
excellent links, thanks!
storch
