Today at 6:41 pm by 962porsche
Yesterday at 10:58 pm by 948
» Oil Pan question
» 83' Porsche 944 LM7 Build
» Throttle body question
» Posche 924 Audi 4.2 V8 ABZ
» Magnuson supercharged car?
LSx hood clearances
LSx hood clearances
Post  m73m95 on Tue Jul 07, 2009 8:37 pm
Has anyone had any trouble fitting the larger 90mm or 92mm throttle body on an LS engine under the stock hood without modifying anything (Engine mounts, cross member)? The cable driven TB looks quite a bit smaller than the electronic one in the GTOs, but does it matter which setup we use?
m73m95
Re: LSx hood clearances
Post  m73m95 on Fri Jul 10, 2009 12:44 am
No one.... really?
Or is that a dumb question, and I can find the answer if I do a little research? lol
m73m95
Post  Vorsche944 on Fri Jul 10, 2009 10:04 pm
I am putting a larger TB on mine and would not think there would be an issue.
You can trim away the underside of the hood to get some extra clearance or
Get some strut spacers and lift the car up the same as the cross member spacer, per xschops design and get some space back that way.
Still not sure you would need the space.
Vorsche944
Post  Admin on Sat Jul 11, 2009 8:38 pm
I would think the over all exterior body size would be the same, Just the inside would have the larger bore.
Post  gt1scca on Sat Jul 11, 2009 10:15 pm
There are manufacturing "differences" in the crossmembers between different cars, and uni-body cars ALWAYS twist and flex to different extents. Some cars are more severe than others. For example, I have seen torqued-up Mustangs break factory welds @ the side quarter windows...
Post  DVC on Mon Jul 13, 2009 7:11 pm
I had to clearance the underside of my hood to run a FAST 92. Now I'm running a Holley and it's much lower profile and would probably fit with no issues, under a stock hood. I believe the FAST was higher profile than the stock electronic 90mm.
DVC
Post  m73m95 on Mon Jul 13, 2009 7:40 pm
Sweet, thanks DVC. That's just what I was looking for.
I planned on the Holley 94mm TB, but I might stick with the 92.
m73m95
Post  cfgioja on Mon Nov 23, 2009 6:04 pm
I just manage to get my car running. The ls1 I have is running a 90mm TB. The top corner closest to the front of the car seemed to hit the hood during test fits,( I could see the paint scratches on the interior of the hood) So I just cut a little square area out of the middle support frame. Not too much just enough to clearance the TB and hood.
