» Fuel tank over pressurizing
» LS Conversion Kit Plus
» tips on removing headers?
» Oil Pressure
» Mass oil leak!?
» SBC Pilot Bearing
» Lighten clutch pedal feel?
February 2019
GM 3800 V6 swap
Page 5 of 5 Previous  1, 2, 3, 4, 5
Post  n2mprtz on Sun Nov 03, 2013 9:53 am
Suspect Any forward ACTION on this..? Arrow
n2mprtz
3800 swap
Post  maareeo on Tue Nov 05, 2013 7:01 pm
Hello guys, It,s been awhile, and sorry about not replying to anyones inquiries sooner, just been too busy and or too lazy. I am in Queens NY, I will be posting pics of my 3.8v6 swap along with solutions for swap head aches, Its been a long journey with trial and error on parts. hope to save someone time and money. my email is [You must be registered and logged in to see this link.] i could send pics via phone if needed.
maareeo
pics are in my gallery
Post  maareeo on Fri Dec 13, 2013 1:14 pm
I have posted a few pics of my swap on my gallery
maareeo
Re: GM 3800 V6 swap
Post  acorad on Fri Dec 13, 2013 2:56 pm
How does the steering feel now with the heim joint in comparison to how it felt before?
Re: GM 3800 V6 swap
Post  maareeo on Fri Dec 13, 2013 8:07 pm
Steering itself feels good, the most important part is the angle, should not be more 33-35 degrees, if it is, you'll feel it, i used the borgeson joints, but i recommend using the d shaft or double d, they are safer and easier to modify if needed with out messing the joints up
maareeo
Re: GM 3800 V6 swap
Post  maareeo on Wed Dec 18, 2013 10:55 am
Hey guys, for anyone interested in contacting me, use my email in my profile as I cant reply via PM yet due to not enough postings
maareeo
Re: GM 3800 V6 swap
Post  v2rocket on Sat Feb 08, 2014 11:36 am
Is this kit still able to be produced?
v2rocket
Re: GM 3800 V6 swap
Post  CK5TOY5 on Tue May 26, 2015 11:40 pm
Really interested in doing a 3800 twin turbo set up in my 87 944S. Is there any word on this becoming a kit? If not what is the cost for install?
CK5TOY5
Re: GM 3800 V6 swap
Post  xschop on Wed May 27, 2015 8:07 am
What are the crank/snout dimensions? I see where the Camaro uses a 15mm ID bronze/oilite pilot bearing....
Heavy Duty; Bore=0.592", Outer Diameter=0.829", Width=0.755"
Heavy Duty
I found a 2.2l s10 auto Bellhousing on eBay and snatched it up.
Re: GM 3800 V6 swap
Post  xschop on Mon Jun 15, 2015 6:32 pm
GM part# 24205617
It's 6.25" deep and can accept a max dia. Flywheel starter ring of 12.50".....
Re: GM 3800 V6 swap
Post  drive135mph on Tue Aug 18, 2015 1:12 am
Hey It's been a bit since i read through this thread but it looks like if you retain the stock 3.8 flywheel an pressure plate, you would need a clutch with the porsche's 1in by 23 spline input but the camaro's 9.49 diameter. [You must be registered and logged in to see this link.]
that clutch should fit.... no custom clutches
drive135mph
pilot bearing
Post  Sirayden on Thu Aug 27, 2015 5:07 pm
Anyone know if there's a pilot bearing that could fit in the 3800 series II? Seems like I heard that a bronze bushing couldn't be used due to the shaft's tip not being heat treated. Thanks!
Sirayden
Re: GM 3800 V6 swap
Post  jwink25 on Thu Jul 07, 2016 10:11 am
Any updates? Will there be a kit made?
jwink25
Re: GM 3800 V6 swap
