Headlight Buckets
Headlight Buckets
Have to credit where due.
Just received my headlight buckets from Eric at Texas Performance Concepts, they are very good.
I was falsely under the impression that I was going to have to get rectangular headlight mounts from a wrecking yard but Eric's buckets come with the mounts and adjusters included. I'm very pleased, thanks Eric.
Re: Headlight Buckets
I have to disappoint you a little! The metal bucket part is from the salvage yard, Although as you can see they are refurbished to meet our needs.............
Very nice!
Have you looked into a retrofit HID? I'm going to be going HID in a week or so here, so keep an eye out for my build Mine will be in the stock pop-ups, but it should easily transfer over to what you're doing.
Headlight buckets
Yes i did consider the HID option as TPC provides the buckets set up for either type.
I decided to go to rectangular and see how it works out. Maybe later when I have finished the swap/suspension/brake upgrade etc. I will look at the HID option.
Correct me if i'm wrong, but i think the kit offers an option for projector headlights, not necessarily HID. I'm going with a real OEM type HID high/low beam projector setup (not the ebay crap). It's surprisingly affordable, i spent about $200 total.
At any rate, it's definitely something you can do at a later date.
have you installed these yet? and do you have any pics? I want to go down this road myself.
lvkid76- Posts : 12
Headlight buckets
No, have not installed them yet. I plan to start my engine swap and other upgrades in the New Year.
