» Headers, headers, HEADERS!
» Electric brakes
I need a manual steering rack
Post  kelleysj on Tue Nov 16, 2010 6:33 pm
Looking for a manual steering rack seem to be NLA on paragon and 944 online anyone know where i can find one. I have an 88 N/A
kelleysj
Re: I need a manual steering rack
Post  Arthropraxis on Tue Nov 16, 2010 6:43 pm
I got one off of Ebay. They come up every now and then on Rennlist. You are going to have to convert it to late offset. One method is found here [You must be registered and logged in to see this link.]
Post  MN944S on Tue Nov 16, 2010 9:33 pm
Just a heads up to anyone converting to manual on a late car and using the thread-rod method that was mentioned in the link above:
I bought the 30" or 36" "stick" of M14 thread-rod and I think it was a quantity of 25? of the jam nuts from McMaster-Carr. Needless to say I have enough thread-rod and jam nuts (you need 4) to do several more early rack to late outer tierod conversions. I highly doubt I'll be doing more than one.
Not looking to make money off it, just help out and maybe break even.
PM me if any interest.
Or you can spend $35 or so plus shipping and have plenty of leftovers like me! Smile
Either way works.
MN944S
Post  Arthropraxis on Wed Nov 17, 2010 7:02 am
You can just weld the rod into the power tie rod end then you won't need the other jam nut.
Post  xschop on Wed Nov 17, 2010 7:36 am
I've posted many times that Moog EV-378 inner tie rods are a bolt-on solution....
Post  Arthropraxis on Wed Nov 17, 2010 7:53 am
I put that in the manual steering how to.
Post  storch on Wed Nov 24, 2010 5:09 am
399 at autozone (core included)
that's the only place that seems to still have them available
storch
Post  aixgelo78 on Wed Nov 24, 2010 8:57 am
Id give them my PS rack as a core.....you will need a steering shaft, but I had to extend mine since for some reason, my 1/2 spacers changed the geometry of the shaft and needed to be extended. Therefor, you can use your existing one and extend it as you see fit.
aixgelo78
Post  944-LT1 on Wed Nov 24, 2010 9:15 am
Rockauto has them cheaper 284 + 28 core but they will charge shipping (probably both ways) whereas I believe AZ doesnt.
As for the steering shaft, both summit and jegs sell the correct u-joints (xschop) to do some radical header clearing mods to the shaft. Very Happy
Craig Hardy Wrote: This is a shot of the drivers side...notice the extra joint in the steering shaft to clear the exhaust manifold. RH modified the steering shaft for me as well as the motor mount that now has a mounting bracket to locate the steering shaft. The other option is to modify some Carb legal shorty headers to clear the shaft.
